Documentation for Users
2.0.6
Perception Toolbox for Virtual Reality (PTVR) Manual
You can recover the position coordinates (specified in the Global Coordinate System) of an object by using the following code:
my_object.get_position ()
a/
my_object.get_position () does not return the correct coordinates of "my_object" if my_object has been rotated before with either my_object.rotate_to_look_at () or rotate_to_look_at_in_opposite_direction ().
b/
This limitation also occurs if the parent of "my_object" (if there is a parent) has been rotated either with my_object.rotate_to_look_at () or my_object.rotate_to_look_at_in_opposite_direction ().
More information on orientations of objects: HERE
Path of Demos: ...\PTVR_Researchers\Python_Scripts\Demos\Coordinate_Systems\
| Python file | Description |
| 50_get_global_coordinates_of_objects.py | Does what it says. |
| 51_get_global_coordinates_of_objects_placed_on_tangent_screen.py | Does what it says.
